First check to see if you have power to the coil. The coil is not getting power it will not produce spark.
You can check for power using a voltmeter.
This could be also due to a faulty ignition control module.
And of course, you could have a faulty coil.
Take a look at this guide it covers on how to check the ignition system:
Images (Click to enlarge)
Dec 3, 2021 at 12:23 PM
