1994 Chevy Truck hydraulic clutch
70,000 MILES • V8 • 4WD • MANUAL
FRANKM
the clutch has a slow leaki. I need to add fluid to get it to where it can be repaired. Do I simply add fluid to the reservoir or do I have to remove the diaphragm first, and what is the proper fill level?
Nov 15, 2008 at 2:14 AM
DOCFIXIT
  • 18,828 POSTS
Tes pull out the rubber piece and fill to line marked on resevior. Pump couple times to burp out air. and go for help.
Nov 15, 2008 at 4:06 AM
