1994 Chevy Truck Fuel problem!
99,500 MILES • 6 CYL • 4WD • MANUAL
MADTRAPPER31
While driving my truck it feels like the engine is surging like its not getting enough fuel! I just changed the fuel filter, air filter , cap, rotor , wires, plugs and the map sensor but still have the same problem! All my vacuum lines are in good condition and the truck idles fine and doesn't sound like it is running roughwhile I feel it surge! Im almost ready to burn it to the ground!!!
May 18, 2009 at 12:18 PM
  • 75,988 POSTS
Check the fuel pressure and also clean out the idle air control valve and test TPS.
May 18, 2009 at 12:23 PM
