1994 Chevy Truck engine oil
160,000 MILES • V8 • 4WD • AUTOMATIC
FRED SABLE
upper engine noise,no oil coming up push rods,40 psi of oil pressure, disassemble engine,no problem found. this happened when it was 20 below.Drove the veicle about 20 miles when i got upper engine noise.note 454 chev
Feb 21, 2009 at 7:02 AM
STEVESBS1
  • 11 POSTS
sounds like you might need to check your cam bearing may have spun one
Feb 23, 2009 at 3:52 AM
