oil pressure gauge raises to high point
156,000 MILES • 6 CYL • 4WD • MANUAL
POWERMAN_270
the oil pressure gauge raises to high point?
Dec 4, 2008 at 5:34 AM
  • 75,988 POSTS
Check the fuel pressure if okay inspect and test the oil pressure sending unit-when you turn key to run it powers the pump for 2secs-primes the system when engine fires up the oil pressure sending unit powers the fuel pump
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_87.gif
Apr 21, 2021 at 5:07 AM
