1994 Chevy Truck acceleration stumble
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
DUSTY_OGLESBY
i have a problem under acceleration, when you push the gas it spits and sputtersand slowly clears up. I have replaced the map sensor and the tps. What else could it be?
Jan 28, 2008 at 2:46 AM
MERLIN2021
  • 17,250 POSTS
Could be a vacuum leak, a stuck EGR, Low fuel pump volume or plugs, wires filters...Compression is OK? Check engine light on?
Jan 28, 2008 at 2:58 AM
