1994 Chevy Truck
HFACE8
Engine Mechanical problem
1994 Chevy Truck 6 cyl Two Wheel Drive Automatic
94 CHEVY TRUCK 4.3L SAT FOR 2 YEARS WONT START ENGINE TURNS OVER HAS SPARK NEW FUEL PUMP HAS GOOD FUEL PRESSURE TO BACK OF THROTTLE BODY CHECKED FUEL INJECTOR CONNECTORS WITH NOID LIGHT TESTS GOOD CHECKED GROUNDS NEED HELP
Feb 28, 2009 at 7:03 PM
JDL
  • 16,098 POSTS
Hello, if you have the TBI fuel system, you should be able to see the injectors spray? Can you feel or hear the injectors click?
Mar 1, 2009 at 2:21 AM
HFACE8
have tbi fuel system no spray from injectors can hear the injectors click
Mar 1, 2009 at 5:10 AM
JDL
  • 16,098 POSTS
The injectors may be clogged or something wrong in the throttle-body.
Mar 1, 2009 at 6:04 AM
