1994 Chevy Truck
BARNAUT
1994 Chevy Truck
I have a 94 1500 and my brake lights work just fine, but my dash lights, turn signals and tail lights all went out at the same time. My fuses are good. Any ideas? Thanks
Feb 17, 2009 at 5:05 AM
JDL
  • 16,098 POSTS
Hello, not only check the fuses, check that the fuse circuits are hot when they should be.
I believe the dash and tail-lites work off the same circuit activated by the headlite switch.
The turn and stop at the rear use the same bulb filament, not at the same time. They're wired through the turn switch.
Feb 17, 2009 at 6:22 AM
UBERHUND67
if u havent fixed it yet then i may have a answemy 94 chevy has the light switch on the dash
i had to take switch out and clean it
it has i believe 3 contacts and the one feeding the headlights were fine but the dash and the tails and running lights did not come on
all u need to do to take the switch apart and clean it
mine has worked fine for 1.5 yrs now after i did that
Feb 21, 2009 at 4:15 AM
