1993 Chevy Truck Vibriation
125,000 MILES • V8 • 4WD • AUTOMATIC
DARTANION
Have a 1993 Chevy K1500, When cruising at highway speeds there will be a vibration felt which feels like it is coming from the rear, if let off the gas the vibration goes away or if you step on the gas as to pass it will go away also. It only starts this if you slightly press the gas, there is no vibration when idle, and it will start at different speeds. Have replace the U-joints.
Nov 8, 2008 at 8:55 AM
  • 31,937 POSTS
Hi there,
if this has a 2 piece tail shaft, check the center bearing, if it is a 2 piece shaft was it marked so it was still in phase, (both shafts aligned as they were? also check the rear tyres and rims foe a problem, have seen dried mud on the inside of a rim cause this.
Mark (mhpautos)
Nov 8, 2008 at 10:47 AM
