1993 Chevy Truck surging
16,000 MILES • V8 • 4WD • AUTOMATIC
RIDOHU
I was wondering what might be causing my engine to rev up and down on a cold start only. Once it warms a little it stops and idles smoothly. Everything is new. New gmt crate engine, engine electronics, fuel pump,fuel filter, Tps, iac valve though I have to clean it regularly. Thank you.
Dec 26, 2009 at 1:11 PM
  • 75,988 POSTS
Try cleaning out the idle air control valve again and test the MAP sensor to include checking the fuel pressure if its within specs.
Dec 26, 2009 at 1:21 PM
