1993 Chevy Truck Problem with lights and wipers
SOONERB2
Electrical problem
1993 Chevy Truck V8 Four Wheel Drive Automatic
My windshield wipers will come on when I put the low beams on, when I put the high beams on the wipers will go off, also with the low beams on the left turnsignal on the dash will be on. I changed out the Turn signal multi switch but it did not help. Do you have any ideas of what could be the problem.
Thanks,
Paul
Mar 6, 2010 at 4:47 PM
HMAC300
  • 48,601 POSTS
check to make sure your grounds are good. The one to the battery to the body and engine to body. Also check under the dash and see if htere are any ground wires there. Make sure that all of them are clean and not corroded.
Mar 7, 2010 at 6:04 AM
