When installing a remanufactured transmission is there a certain way to match up the torque converter to the flexplate
May 18, 2008 at 8:23 AM
PRODRIGU
MEMBER
first put the torque converter on the transmission and make sure when you mount it to the transmission that you rotate the torque converter as you push inward towards the transmission and it should seat 3 times, thats when you know its on right, when bolted up just match any of the holes on the flex plate to the torque converter and bolt it down.
