1993 Chevy Truck four wheel drive
165,000 MILES • V8 • 4WD • AUTOMATIC
HERTZ1974
I put my truck into 4 wheel drive today, had clunking noise from front end. started driving around 35 when you let off of gas the noise turns to a grinding noise hit the gas again noise is gone. When coming to a stop the noise is there the whole time. Taking off again starts banging and clunking again. Checked all fluid levels all are ok, brand new tires and new transmission. everything work fine last season this truck has a snowplow. thanks for any help you may have
Dec 9, 2009 at 1:51 PM
  • 110,248 POSTS
Have you checked for play in the output bearing from the transfer case and the input to the front diferential. It sounds like a bad bearing. Also, check the u-joints.
Let me know what you find.
Dec 12, 2009 at 5:55 AM
HERTZ1974
found a bad transfer case inside fluid was grey with metal replaced everything is fine now.
Dec 13, 2009 at 4:05 AM
