1993 Chevy Truck engine oil
144,000 MILES • V8 • 4WD • AUTOMATIC
ADAMGEHRKE
i have a 93 chevy k3500 that when you start it the oil pressure is at 60 psi and after a few minutes it drops to 5psi and i find that there is no oil getting to the top end of the engine has new oil pump already installed
Apr 30, 2008 at 11:32 AM
PEAR69
  • 1,482 POSTS
The oil pick up is probably installed too close to the bottom of the pan.
May 8, 2008 at 10:47 PM
