1993 Chevy Truck chevy truck steering column wiring color c
GENE62
Electrical problem
1993 Chevy Truck 6 cyl Two Wheel Drive Manual
Looking for the wiring color code to install a
1997 chevy S-10 steering column to a 1993 chevy 1500 truck wire harness .I know there is going to be extra wires on the 1997 S-10
Thanks
Gene
Feb 7, 2010 at 8:07 AM
HMAC300
  • 48,601 POSTS
the best way to do this is go to a library or get a manual for a 97 S truck and check the harness that way. Try to do the same with the truck you are installing the column. It stil may give you problems though....
Feb 7, 2010 at 9:43 AM
