1993 Chevy Truck
WITTHUDSON
  • 1993 CHEVROLET TRUCK
Engine Mechanical problem
1993 Chevy Truck 6 cyl Two Wheel Drive Automatic
I COME TO A STOP LIGHT AND THE ENGINE STALLS IF I CONTINUE TO CRANK IT, IT WILL START BUT ONLY STAY RUNNING IF I HOLD GAS ABOVE IDLE
Monday, June 21st, 2010 AT 10:00 AM
INTERNETMECHANIC
  • 700 POSTS
Sounds like you may have a problem with the idle air? You may need to clean the throttle-body and check the iac, idle air control. Any applicable trouble codes? How long since a tune-up?
Monday, June 21st, 2010 AT 10:15 AM
WITTHUDSON
The tune up was done about 2 months ago wires about 3 weeks ago and fuel filter 3 weeks ago
Monday, June 21st, 2010 AT 11:00 AM
INTERNETMECHANIC
  • 700 POSTS
Right now, I'd look at the iac, also the passages may need cleaning? Any codes?
Monday, June 21st, 2010 AT 12:17 PM
WITTHUDSON
Cleaned it now so far running good thank you
Monday, June 21st, 2010 AT 12:54 PM
