car engine shuts off after fifteen to twenty minutes of running
173,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JAMES SMITH SR
The truck will cut off between fifteen to twenty five minutes whether you are idling or driving. just like you turned the switch off. I have replaced electric fuel pump, coil, throttle position sensor, ECM /PCM , coolant temperature sensor , knock sensor, map sensor, fuel pump relay and idle air control sensor. Do not Know if I left something out . Can you help me figure this out?
Oct 15, 2016 at 6:25 AM
HMAC300
  • 48,601 POSTS
scan for codes first. get back to us with codes or look in repair guide on site. also check for soft vacuum lines to map sensor on firewall and any other one as it may be sucking closed cutting vacuum off and engine. finally have ignition module checked at auto parts it may be heating up and going bad and use dielectric grease when reinstalling. also check wires leading to pick up coil in distributor for frayed/chafed etc. also if you have a tachometer pull the white wire on distributor and if it quits the tachometer is the culprit.
Oct 15, 2016 at 8:55 AM
