1993 Chevy K1500 4WD Won't Engage
JETPILOT244
I have a 1993 chevy K1500 pick up. The four wheel drive will not engage. I was told that the actuator on the front differential may have gone bad. It is the original one one the truck. The truck has 148,000 miles on it. I was told that the original actuator had a gas in it that would be heated up by an eliment when engaged. The new actuatore is supposed to be all electrical. My question is: is it the actuator or the engagement switch that is bad. Or is the switch just to turn on the indicator in the cab?
Jan 26, 2007 at 11:13 AM
2CARPRO JACK
  • 11,533 POSTS
Is it a manual lever transfer case? That year can go either way. In the early GM's the button was to disable the ABS so if half the vehicle left the ground the ABS wouldnt freak out. The front actuators were a HUGE problem (freezing up- just plain not working).
Jan 26, 2007 at 11:43 PM
JETPILOT244
it is the manual 4 X 4 Lever on the floor. 4 wheel low does not work either.
Jan 27, 2007 at 12:36 AM
2CARPRO JACK
  • 11,533 POSTS
Check the actuator
Jan 29, 2007 at 1:41 AM
JETPILOT244
I check the actuater and it was bad. I did not have to put the updated fast acting one on. My parts place had the original so I wouldn't have to run the new wire harness back to the transferr case.
Thanks for the help.
Jan 31, 2007 at 7:29 AM
Suggested Repair
Check the front differential actuator. On this truck it was bad and was replaced with an original-style actuator so a new transfer-case wire harness was not required.
Conversation Summary
The owner of a 1993 Chevy K1500 with a manual floor-mounted 4x4 lever reported that four-wheel drive would not engage in high or low and asked whether the front differential actuator or the engagement switch was at fault. The expert noted that early GM front actuators commonly fail and advised checking the actuator. The owner later confirmed the actuator was bad and replaced it with an original-style unit.
