1993 Chevy Cavalier Stalls at Stops
I.A.C. -- Idle Air Control -- Responsible for regulating engine idle speed.
T.P.S. -- Throttle Position Sensor -- Reports to the computer the position of the throttle which is responsible for calculating the proper air/fuel mixture.
You may also want to check the M.A.P (Manifold Absolute Pressure) sensor.
The I.A.C. is the most costly to replace (over $100) for your vehicle. I recommend just having it cleaned. The M.A.P. sensor is cheap, about $30 for the part. The T.P.S. sensor is also rather cheap and goes for about $25-$30.
I have my doubts over-the-counter-two-dollar fuel injector cleaner will fix the problem. A true fuel injection service is between $80 to $120 depending on where you take it.
The gas cap is good information. The system may not be at the proper pressure.
Let me know how things turn out.
Suggested Repair
Because the stalling occurs without driving above about 40-45 mph, do not focus on the torque converter clutch solenoid. Have the idle air control valve cleaned and inspect the throttle position sensor, manifold absolute pressure sensor, and fuel pressure, including the fuel filter and pump. A professional fuel-injection service is preferable to inexpensive cleaner. Also confirm that the replacement gas cap seals properly and is not overtightened.
Conversation Summary
A 1993 Chevy Cavalier stalls and idles unevenly when coming to a complete stop after an ignition sensor replacement. The owner said speeds are usually below 45 mph, the fuel pump was checked, and a fuel filter was replaced. An expert recommended checking the idle air control valve, throttle position sensor, manifold absolute pressure sensor, and fuel pressure, while explaining that the torque converter clutch solenoid applies only after higher-speed driving. Another owner suggested injector cleaner, but the expert doubted an inexpensive cleaner and recommended a professional injection service. The owner later associated some bogging with an overly tight replacement gas cap and reported little improvement from cleaner before planning a mechanic visit.
