1992 Chevy Truck swap
1992 CHEVROLET TRUCK
CAREREPAIR2008
Transmission problem
1992 Chevy Truck V8 Four Wheel Drive Automatic
I have a 1992 k1500 it had a 5spd in it and it was bad. I can't drive manual for long distences anyway so I'm changing to an automatic (700r4). I've already got the trans in with the new drivshafts. Ive got everything done but the torque converter lock up. I've got it set up for manual lockup but I dont like it. My question is can I run the lock up through the computer. the trans has 3 wires tan\black, Lt blue, and purple.
I think that the tan\Blk should go to the A7 pin on the computer (shift light). purple to 12v or C7 pin. and Lt blue to brake switch. but I'm not sure and don't want to mess this trans up.
Nov 22, 2009 at 4:41 PM
DR LOOT
  • 2,311 POSTS
The 700R4, is not a computerized transmission, therefore you will need to install a toggle switch, to manually activate the converter lockup.
Nov 27, 2009 at 10:05 AM
CAREREPAIR2008
I'm not using a powertrain computer I'm trying to run it off the ecm just like the foctory would have if this truck came with the auto trans. The 700r4 would have came in this truck from the factory. Therefor I know I can do it I'm just doing research tryin to find out the pieces I don't already know. I've got the wires going to the computer the rite way I just have to replace the prom chip with one from an automatic. I thank you very much for the reply your one of the few who have even said anything back.
Nov 28, 2009 at 10:09 AM
DR LOOT
  • 2,311 POSTS
I will be here to continuously assist you with any problem you may run into. I am sending you a diagram of your transmission wiring harness.
https://images.2carpros.com/forum/automotive_pictures/307270_Graphic_1992_Chevy_1.jpg
If you cannot read the diagram. Send me your e-mail address, and I will send it to you as a photo so you can enlarge it.
Nov 28, 2009 at 11:56 AM
CAREREPAIR2008
thank you very much from what I can tell this looks like the diagram I've been looking for here is my email if you can please send that to me so I can take a closer look carerepair2008@yahoo.com Thanks again
Nov 29, 2009 at 4:43 AM
TOMAS MARKLEY
Dr loot can you email me the picture of the Wiring diagram? I need the one for the harness on the driver's side of the motor to the transmission. I'm trying to figure out where this plug goes on the 700r4. Someone got into the wiring and completely rigged the repair of the splice and it came apart when I was pulling the transmission.
Oct 13, 2019 at 6:32 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately, You've attached your question to one that is years old.You need to start a new question and be sure to include your vehicles information.Here is the link:
Once you do this we'll be happy to provide any advice and diagrams.Hope this helps and thanks for using 2CarPros.
Danny-
Oct 13, 2019 at 9:04 AM
