1992 Chevy Truck problem with brakes
110,000 MILES • V8 • 2WD • AUTOMATIC
ABLEMECHANICS
There was a problem with the brakes the parts are all new pads rotors drums lines. the pedal was falling through and there was a swoosh sound when pressed. we replaced the master cylinder and the praportaning valve, ive bleed the brakes everywhere possible multiple times and the pedal still goes all the way down with the same sound. the only thing left is the booster but thats not fitting the symptoms. please help
Dec 14, 2009 at 7:01 AM
  • 110,246 POSTS
Two things to check. First, make sure the front rubber brake hoses are not expanding when the brakes are depressed. Next, the pushrod between the pedal and the master cylender, is it adjustable?
Dec 22, 2009 at 1:39 AM
