1992 Chevy Truck FUEL CUTOFF SWITCH
1992 CHEVROLET TRUCK
150,000 MILES • V8 • 2WD • AUTOMATIC
JORCARSIL
  • 12 POSTS
I WANT TO KNOW TO INSTALL A FUEL CUTOFF SWITCH,
Mar 15, 2010 at 4:42 PM
For what reason do you need one-you already have the oil pressure switch in the event of an accident-no oil pressure the fuel pump is disable
Mar 15, 2010 at 7:08 PM
JORCARSIL
  • 12 POSTS
i need the switch so a thief wont try to drive away with my car
Mar 16, 2010 at 6:48 AM
Find the gray wire at the fuel pump connector and cut it open at your toggle switch connect one wire to the wire coming from the engine and the other going into the fuel pump then go hide it somewhere close by you
Mar 16, 2010 at 7:28 AM
JORCARSIL
  • 12 POSTS
where do i find the wire that comes from the engine and what color is it. thank you
Mar 16, 2010 at 7:51 AM
You can do it right there at the fuel pump wire connector or find the fuel pump relay tie in at the gray wire
Mar 16, 2010 at 10:31 AM
JORCARSIL
  • 12 POSTS
ok thanks! so i connect the grey wire from the fuel pump relay to the toggle switch and another one from toggle switch to the grey wire from the fuel pump connector.... Is the fuel pump connector the one that has wires coming out the fuel tank...Thanks for all the help
Mar 16, 2010 at 2:27 PM
That's a big 10-4 buddy
Mar 16, 2010 at 4:50 PM
JORCARSIL
  • 12 POSTS
sorry to bother again but do i have to cut the existing wire and put my new wire
Mar 17, 2010 at 3:44 AM
You have to -to run the switch in series with the circuit to control the fuel pump.
Mar 17, 2010 at 8:14 AM
JORCARSIL
  • 12 POSTS
ok thanks alot....do u know to do it for a 2002 honda accord
Mar 17, 2010 at 10:29 AM
Just find the wire that powers the fuel pump and do the same thing
Mar 17, 2010 at 10:31 AM
JORCARSIL
  • 12 POSTS
do you know what color are they
Mar 18, 2010 at 3:39 AM
What liter engine? 4 or 6cyl
Mar 18, 2010 at 8:11 AM
JORCARSIL
  • 12 POSTS
4 cyl
Mar 19, 2010 at 4:26 PM
Its black and yellow wire
Mar 19, 2010 at 4:48 PM
JORCARSIL
  • 12 POSTS
which one comes from the pump and which one comes out of the relay
Mar 19, 2010 at 5:54 PM
The same color wire at the relay and at the pump if I were you do it at the relay side instead at the pump side prevents you from crawling underneath lol
Mar 19, 2010 at 6:02 PM
JORCARSIL
  • 12 POSTS
lol ok thanks alot man i had one more question but i feel weird asking since i ask u a lot them already
Mar 19, 2010 at 6:08 PM
What's the question?
Mar 19, 2010 at 6:10 PM
JORCARSIL
  • 12 POSTS
i have a 2002 gmc sierra 2500 v8 and a 95 dodge neon 4cyl and want to put the switch on them and i would like to know what color are the wires
Mar 19, 2010 at 6:17 PM
Neon: its a dark green and white from relay to fuel pump same wire
Sierra: gray wire from relay to fuel pump same wire
Anything else lol
Mar 19, 2010 at 6:50 PM
JORCARSIL
  • 12 POSTS
no thats it thank you very much... do you know what kind of performace parts can i put on the 92 chevy truck that would make it go fast
Mar 20, 2010 at 5:02 AM
