1992 Chevy Truck ENGINE STALLS WHILE DRIVING
JAMINJ
  • 1992 CHEVROLET TRUCK
  • V8
  • 4WD
  • 162,000 MILES
If I let the truck idel for 10 to15 minutes it will stall. You can drive short distances butt if you drive to far the engine stalls pull off road wait a few minutes starts fine few miles stalls again. Have replaced alternator belts plugs wires rotar all new msd products.I have two small children and so I dont drive truck with them. Can you advise maybe fuel pump filter and blow out fuel lines or do fuel pressure check?
Monday, March 22nd, 2010 AT 12:40 AM
Next time it stalls do below immediately don't wait for nothing to determine if its fuel or spark problem and come back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, March 22nd, 2010 AT 5:57 AM
