1992 chevy k1500 4wd 200,000 miles replaced tps, cap and rotor, spark plugs, wires, fuel filter, has 9-10 pounds on fuel pressure, tested control module, its good, the codes it read are electronic control module failure, fuel pump relay, o2 sensor lean. The truck idles fine but cuts out and runs fine when full throttle it will sputter and die when taking off. Any suggestions
SPONSORED LINKS
Tuesday, October 27th, 2009 AT 9:30 PM
