1992 Chevy Truck Alternator
1992 CHEVROLET TRUCK
JGCF57
  • 8 POSTS
Electrical problem
1992 Chevy Truck V8 Two Wheel Drive Automatic alot miles
This truck has a new battery and alternator. At idle, the dash gauge reads 14v. with the headlights on but when I rev. the engine the voltage drops to 9v. and the lights dim noticeably. What's up with that? I know you guys don't like life-time warrantied alternators but they said it tested fine. What do you think?
Thanks for your help.
May 29, 2008 at 10:54 PM
PEAR69
  • 1,482 POSTS
Check the voltage regulator. It does sound like a failing alternator.
May 30, 2008 at 3:13 AM
PEAR69
  • 1,482 POSTS
Check all the grounds too.
JGCF57
  • 8 POSTS
[quote:344434bcdb="pear69"]Check all the grounds too.[/quote:344434bcdb]
This sounds logical. However, since the old guy who owns the truck changed his fuel supply the problem went away. I said "bad" gas has no electrical effect on the fuel injectors and the current draw on injectors has little to no effect on headlights but until he empties the tank and refills with the "bad" gas to "prove me wrong", I can do nothing. I believe what I told him was true and I will let you know what happens. Thanks for your help.
jgcf57
May 31, 2008 at 10:04 PM
PEAR69
  • 1,482 POSTS
Hmmm, bad gas causing a voltage drop--interesting, very interesting----please get back to me on this one----please..
Jun 1, 2008 at 4:16 AM
