1991 Chevy Truck Service Engine Light
EDGE56
  • 1991 CHEVROLET TRUCK
  • 6 CYL
  • 168,000 MILES
This truck has had better days but I just bought it. The other day the service engine light came on after about 4 miles of driving. I turned the key off and then restarted the truck and the light was of but came back on after about 4 miles of driving again. This happens everytime. Since I purchased the truck I have done the following: Changed the oil and filter, changed the transmission fluid and filter, and changed the spark plugs. Any ideas what could be causing this to happen? The truck still runs fine even when the light comes on. I checked the gas cap and that doesn't seem to be the problem so I am really confused as to what to check next
Wednesday, October 29th, 2008 AT 6:03 PM
DLOBI
  • 125 POSTS
Take it to your local auto parts store or repair shop and have them pull the code that is turning on the check engine light. Most auto parts stores and shops will do this at no charge.
No use fixing things until you know what needs fixing :)
Wednesday, October 29th, 2008 AT 6:19 PM
