1991 Chevy Truck removing the drive shaft
250,000 MILES • V8 • 2WD • AUTOMATIC
BUDSELECT
help me figure out why I can't break loose the drive shaft from the rear differential
Sep 19, 2009 at 7:58 AM
DR LOOT
  • 2,311 POSTS
after you have removed the four bolts, . You will have to take a prybar and put it through the yoke, most likely the U-joints are pressed in very tight, if you have a carrier bearing in the middle of your driveshaft. You will have to unbolt it from the chassis before removing the driveline from the rear end.
Jan 10, 2017 at 4:25 AM
