1991 Chevy Truck carburator
1991 CHEVROLET TRUCK
299,999 MILES • 6 CYL • 2WD • AUTOMATIC
CDANIELSJR
Engine run ok during high speed. but when i stop enging will not idle. it turns off. just replaced water pump and did tune-up. because pump went out and engine over heated and turned off.
Oct 16, 2008 at 1:36 AM
Inspect/Test the Idle air control valve/throttle position, mass air flow, and manifold absolute pressure sensors-to include the EGR valve-won't hurt to check the fuel pressure making sure its within specs-
Oct 16, 2008 at 1:46 AM
