1991 Chevy Truck 4 x 4
157,000 MILES • V8 • 4WD • MANUAL
STURGILL.VERNUS
When I pull the 4-wheel lever to put it into 4-wheel high the floor lights light up but the front differential will not engage. I was told the front axle actuator switch may be bad. The fuse is good and when i put 12 volts to the axle switch the end came out but very slow, does this mean it is good and i have other problems?
Feb 17, 2010 at 12:45 PM
  • 110,248 POSTS
Chances are if it moved slowly, it needs replaced.
Feb 18, 2010 at 1:52 AM
