1991 Chevy Truck
ZANGLE
  • 1991 CHEVROLET TRUCK
Engine Performance problem
1991 Chevy Truck 6 cyl Two Wheel Drive Automatic
91 chev 4.3 v6 pickup starts and runs fine, then dies after a few minutes if running. Have replaced the distributor, injectors, spark plugs ( all tune up parts ), fuel treatment in the tank ( for possible moisture ), the simple computer on this model was replaced about a year earlier. Have heard of a possible grounding issue for the engine?
Sunday, February 15th, 2009 AT 5:42 PM
Starts and runs fine, then dies after a few minutes if running-Double check all ground points
To catch it do below immediatley to determine if its fuel or spark issue
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, February 15th, 2009 AT 5:55 PM
