1991 Chevy Truck
JEEPMUDDER454BBC
  • 1991 CHEVROLET TRUCK
Engine Performance problem
1991 Chevy Truck V8 Four Wheel Drive
I just got 1991 chevy pu 305v8 it had fuel leaks repaired them started flooding bad replaced temp sencer fixed that problem started running ruff so I did a tune up plugs wires cap rotor didnt really help whats next? Im not real good with electronics
Wednesday, May 28th, 2008 AT 7:32 PM
MASTERTECHTIM
  • 4,750 POSTS
Turn on ignition and watch the injectors and see if any fuel leaks out from them. If it does then a piece of dirt is stuck in it. You can also unplug egr valve and tap on it with a hammer to seat it. Its possible its stuck a little open.
Wednesday, May 28th, 2008 AT 7:41 PM
