1991 Chevrolet Cavalier RS Fuses Question
GENIO
I have a 1991 Chevrolet Cavalier RS and my horn no longer works. I tried to look for a fuse box underneath the dashboard but there was none for the horn. I also tried to look inside of the engine but there was none there either.
I was wondering if anyone knew where the Fuse Box that contains the Fuse for the Horn is?
I'd appreciate any help because the car needs to go for an inspection soon and it won't pass if the horn doesn't work.
Thanks
Jun 3, 2006 at 6:37 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:545376310d="GeNiO"]I have a 1991 Chevrolet Cavalier RS and my horn no longer works. I tried to look for a fuse box underneath the dashboard but there was none for the horn. I also tried to look inside of the engine but there was none there either.
Thanks[/quote:545376310d]
I have the exact same problem with my car and i cant find the fuse for it.
Mar 11, 2007 at 3:17 AM
CTA2885
Does your dome light still work as well, or is it just the horn?
Mar 15, 2007 at 12:31 AM
CAVALIERDRIVER65
  • 31 POSTS
[quote:abc3eb5409="cta2885"]Does your dome light still work as well, or is it just the horn?[/quote:abc3eb5409]
my dome light works fine. it's just the horn.
Mar 15, 2007 at 1:19 AM
CTA2885
Check the CTSY Fuse it should be a 20a fuse. See if that is blown. There should be a blck wire running from the steering column to the horn relay, then an orange wire running to the fuse block which leads the ctsy. Let me know how that looks
Mar 15, 2007 at 1:30 AM
