1990 Chevy Truck steering locks up
163,000 MILES • 6 CYL • 2WD • AUTOMATIC
PIRATECDL
When I turn my wheel all the way to the left it locks up and will not return,if I turn all the way to the right it's works fine.There is a new tie rod assembly on the right side and I cannot find anything broken or bent.It seems like it "hyper-extends".Could this be a steering box problem?Thank-you
Jul 13, 2010 at 8:03 AM
HMAC300
  • 48,601 POSTS
it could be a steering problem but if the tie rod was replaced and the front end wasn't aligned, then that may be your problem . But it could be a steering box problem as well. have it checked out.....
Jul 17, 2010 at 5:28 AM
