1990 Chevy Truck Running Rich
133,000 MILES • 6 CYL • 4WD • AUTOMATIC
MBOSLOPER
I've inherrited a 1990 Chevy K1500 with a 4.3L engine. Replaced Catalytic Converter and Oxygen sensor. Exhaust still smells and engine still running rich. Idle runs a bit high. Any suggestions? Possibly an internal engine problem?
Oct 9, 2009 at 5:38 AM
DOCFIXIT
  • 18,828 POSTS
Maybe TBI bleeding and causing rich mix. Hook up timing light aim at TBI spray should be fine and 360 deg patteren . If you see droplets then ijn. needs replacing
Oct 9, 2009 at 6:05 AM
