1990 Chevy Truck fuel system
SCHUMAN_07
  • 1990 CHEVROLET TRUCK
Engine Performance problem
1990 Chevy Truck V8 Four Wheel Drive Automatic N/A miles
I have a 1990 1/2 ton 4x4 5.7L. My problem is that when my truck idles the motor runs perfect but when I push the throttle down past 1/4 way it bogs down and starts to mis-fire and sometimes back fires. I have a brand new fuel filter and a semi brand new fuel pump. Any advice?
Wednesday, June 16th, 2010 AT 10:00 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Thursday, June 17th, 2010 AT 1:06 AM
