wondering where the ac drain tube would be located in a 1990 chevy truck and how i would go about uncloging it thanks
Jun 6, 2010 at 5:36 PM
BLACKOP555
✓Experienced Mechanic
be a little hose running out of the bottom of the evaporator case on passanger side. should see it under vehicle. you can try cleaning it with a pipe cleaner or a pick. but since it plugged up chances are there is debris inside the evap case and the only way to get that out is by taking the case apart.
