1990 Chevy Truck ac drain tube
1990 CHEVROLET TRUCK
129,000 MILES • V8 • 4WD • AUTOMATIC
LYNNMARTIN
wondering where the ac drain tube would be located in a 1990 chevy truck and how i would go about uncloging it thanks
Jun 6, 2010 at 5:36 PM
BLACKOP555
  • 10,386 POSTS
be a little hose running out of the bottom of the evaporator case on passanger side. should see it under vehicle. you can try cleaning it with a pipe cleaner or a pick. but since it plugged up chances are there is debris inside the evap case and the only way to get that out is by taking the case apart.
Jun 7, 2010 at 3:48 AM
