1990 Chevy Lumina APV-Major Oil Leak
1990 CHEVROLET TRUCK
FICTITIOUSSMURF
Engine:
3.1 V6
230,000 miles
I know, it is a hunk of metal junk, but it is what I have. Anyway, I have noticed that this thing is basically bleeding to death. When parked it will leave a huge oil slick that appears to be directly under the front vavle cover. When you look underneath you can see droplets of oil on the crossmember, of the frame, between the wheels and also on the bellhousing. Both of these are in line under the front valve cover.
The oil that is leaking is clean and there is no smoke what so ever from the engine. I have a oil gauge that tells me when it is time to add more oil that I watch constantly. I have very limited means right now and just would like to have an idea of what might be leaking.
Apr 25, 2007 at 9:21 PM
ALVINO
I have the same problem with my car, it happens if you let your car set too long. Your Rear Main Gasket goes, and i heard it costs alot... Currently I'm looking for some tips on how to change the main gasket so i can do it myself, untill then i can't really give you much help on how you can do it.
May 18, 2007 at 4:53 PM
