1990 Chevy Corsica 2.2 L engine
TINOLADOGANA
I tried to replace my PCV valve but i was confused to where it was. According to my haynes manual i located it and screwed it out- it was a plastic casing attached to the valve covers.
the plastic casing was empty and the pcv valve i bought couldnt fit into it
what is going on? did i get the location wrong? am i looking at something completely different? i noticed the plastic casing i screwed off has oil on it and is attached to a hose
please help
tino
Feb 1, 2007 at 9:48 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
first, pcv valve pushes in it does not screw in, second it connects to a hose directly
Feb 1, 2007 at 9:51 PM
HRYK2646
  • 40 POSTS
Lets see if I can help.I have a 91 corsica with 2.2L On the left side of the car ,passenger side ,On top of the valve cover there is a hose that leads towards the fire wall you'll find the PCV valve plugged into it.
Ray
Feb 6, 2007 at 3:57 AM
