Is it an automatic trans. It sounds like a vacum leak in the tranny servo and. Or that servo is injesting tranny fluid up into the engine. Locate your servos pull of the vacum line inspect for fluid. Then trace it to the vacum sorce and disconnect it there and plug off and see if that improves the running. By going to the sorce will tell you if you have a leak in the vacum line itself. Good luck
SPONSORED LINKS
Sunday, January 22nd, 2006 AT 10:30 AM
