1989 Chevy Truck wrong fluid
JEWELS88
Transmission problem
1989 Chevy Truck Engine Size unknown Two Wheel Drive Manual ??? miles
I put brake fluid in the transmission... what do I do to fix this
Feb 10, 2008 at 1:17 AM
  • 75,988 POSTS
Get the transmission serviced-change fluid and filter-Or if you wish have it flushed-
Feb 10, 2008 at 1:38 AM
MERLIN2021
  • 17,250 POSTS
Any rubber seals need to be replaced...this means a teardown, wash and rebuild...Brake fluid will swell any petroleum coated piece of rubber! If it's not leaking from the front and rear seals now, it will...
Feb 10, 2008 at 1:39 AM
