1989 Chevy Truck wont stay running
PGCOWBOY01
  • 1989 CHEVROLET TRUCK
  • V8
  • 178,526 MILES
I have an 89 chevy truck that starts but wont stay running. It is getting plenty of fuel, so I am ruling out the fuel pump and the fuel filter. The truck will start, run for about ten to fifteen seconds, then die as if the ignition was turned off. Even pumping the throttle wont keep it on. If anyone can help I am open to any suggestions you can give. Thanks
Frustrated Chevy Guy
Saturday, November 7th, 2009 AT 10:23 AM
DARKESTNIGHTS
  • 10 POSTS
Ok I may have your answer well 3 answers it might posibly be it one is the pick up coile in side your distributor it might be getting too hot and and then causing it to shut off or the map sensor or even the fuel pump relay getting too hot and shutting down the pump
Thursday, August 19th, 2010 AT 10:28 AM
