1989 Chevy Truck vibration
130,000 MILES • V8 • 4WD • AUTOMATIC
TOM3130
My 1989 chevy 4x4 gets a real bad vibration about 40 mph and up in 2 wheel drive . I know it not in the motor because if you put it in neutral it stops vibrating . is there a way to tell if it might be the transfercase ,transmission or rear diffiiretial
Jan 14, 2008 at 1:45 PM
PEAR69
  • 1,482 POSTS
Vibrations like the one you described are usually u-joint related. Check your u-joints and your pinion bearing for any play..also check your tires. An unballanced tire or excessive mud or dirt build up on the wheel (usually on the inner portion of the wheel) can cause a vibration..keep me posted..
Jan 14, 2008 at 1:53 PM
