1989 Chevy Truck valve guide seals
189,000 MILES • V8 • 4WD • AUTOMATIC
HERIONIMUS
oil leaking pass seals how do i put new ones in
Sep 6, 2010 at 7:00 AM
  • 75,988 POSTS
You can buy a device that lets you pressurize the cylinder through a spark plug hole. This holds the valve closed so you can remove the springs. There are several tools to remove the spring with the head on the engine. Check the parts store or rental place
Sep 6, 2010 at 10:03 AM
