1989 Chevy Truck valve guide seals
HERIONIMUS
  • 1989 CHEVROLET TRUCK
  • V8
  • 4WD
  • 189,000 MILES
Oil leaking pass seals how do I put new ones in
Monday, September 6th, 2010 AT 2:00 PM
You can buy a device that lets you pressurize the cylinder through a spark plug hole. This holds the valve closed so you can remove the springs. There are several tools to remove the spring with the head on the engine. Check the parts store or rental place
Monday, September 6th, 2010 AT 5:03 PM
