1989 Chevy Truck Rear axle
999,999 MILES • V8 • 2WD • AUTOMATIC
ZEKE89C1500
I have the truck jacked up and rear end on jack stands, both wheels off, both drums off.
Should I be able to turn the axle from both sides by the studs? and should I be able to slide the axle from driver side to passanger side? There is like an 1/8 play from side to side is this OK or not? Any help or advice and I will reurn the favor. Thank you.
May 23, 2008 at 9:46 AM
PEAR69
  • 1,482 POSTS
Yes and YES..what is the problem?
May 29, 2008 at 8:43 PM
