1989 Chevy Truck fuel injectors
1989 CHEVROLET TRUCK
75,000 MILES • V8 • 2WD • AUTOMATIC
HAHAHELPME
my truck wont get any gas past the fuel injectors on the throttle body. the whole throttle body has been cleaned and have replaced the injectors twice, but still no gas will get past them and the computer scan doesn't bring up any problems. would you possibly have any ideas what it would be?
May 28, 2008 at 2:23 PM
While cranking engine over listen to the injectors are they clicking ? if not the computer might not be getting an ignition reference signal telling it that the engine is cranking therefore not energizing the injectors- also check the fuel pressure.
May 28, 2008 at 10:32 PM
SWINGWRENCHS4FUN
I got lucky and just found the problem on my 1989 Chevy G20 Van. The van would die every now and then in the past but this time it quit all together. I was pulling my other van into my yard and bumped the bumper on the Chevy G20. The next day it wouldn't start at all.
The problem I found was very similar to yours. I took the lines off the carberuetor and they had plenty of fuel but nothing was coming from my Injectors. I cleaned the Carb and the engine ran when I primed the Carb with Carb cleaner.
I used a test light to confirm that I did have power to the injectors. I tested all the fuses in the fusebox and the last three on the left (horn,parking lights,ECM1) didn't have any power when they are supposed to be hot with key on.
I inspected the outside of the loom where it goes into the firewall and connects to the fusebox and it looked really dry and old so I decided to inspect it.
I took it apart and gently pulled on the wires and low and behold three of them (one red power wire, a tan with white stripe, and a solid white wire) came out of the block with ease. I guess when I bumped bumpers it broke the wires off the tabs all the way.
I traced the wires to the correct spaces on the fusebox, drilled a hole in the firewall and wirenutted and taped them together, put the fuseblock back together and fired her right up! I hope this helps.
Seems like I have read quite afew posts from people with around the same year chevy with no fuel getting past the Injectors.
Jun 8, 2008 at 2:23 PM
