1989 Chevy Truck Desperate help needed
136,578 MILES • V8 • 4WD • AUTOMATIC
SANDMAN1832
I have a 1989 Chevy Silverado 350 4x4. I have rear ABS. I replaced both the brake booster and master cylinder on my truck. I have all new brakes and lines all the way around and new rubber lines in the front. The front brakes were bleed with no problem. I go to do the rear with my vacume pump and I get nothing but fluid and air. I went threw 2 large containers of brake fluid trying to get the air to go away and it don't. My truck wont pass inspection do to excessive pedal travel. Im stuck and need help
Aug 29, 2009 at 4:13 AM
SPEEDYCATO
  • 11 POSTS
Preasure bleed. Open front and rear get you another resevoir lid drill i think 1/2 inch hole install valve stem and apply bicycle pump and pump fluid thru until smooth. if front is good close them off first.
Aug 30, 2009 at 6:00 PM
