Electrical problem
1989 Chevy Truck V8 Four Wheel Drive Automatic
getting no fire to the rotor but ignition power feed line is hot so are the two wires leading to the bottom of the distributor are hot also this is with key turned and while cranking checked all plug ins new coil 2 and had ignition modualtested this is crazy worked all groonds also
Jul 22, 2010 at 3:33 AM
