1989 Chevy Truck
300,000 MILES • V8 • 2WD • AUTOMATIC
LADEFO
The horn is engaging after the vehicle is turned off. I believe I have a loose connection. It happened at night and I am in a restricted neigborhood, so I disconnected the battery until after 9 am this coming morning. I thought I disconnected the horn apparently I didn't, it still sounding. Question where is the horn Located? I am trying it find it while the battery is still disconnected for the neigbors sake.
Mar 16, 2010 at 10:08 PM
DARKESTNIGHTS
  • 10 POSTS
if your horn is coming on after you turn your key off it could be a few things but first the horn is located in the grill infront of your radiator and 2 if you have an aftermarket alarm that is hooked in to your lights and or just the horn it might have a short ..... you can also pull the center cap on your steering wheel abd remove the wire that activates your horn when pressed
Aug 19, 2010 at 2:16 AM
